S7 Hardware Update Problem
Phill77
Aug 2005
Northants
45
I need to install a cp343-1 module which isn't currently listed in my hardware catalog.
When I try to download hardware updates from the internet, I get an error saying a connection could not be established, and to check the address in Settings.
The address it is pointing to is:
http://www.siemens.com/automation/step7-hwconfig2
Is this incorrect, or could it be that the server is down?
Are there any other ways around this. I have 6GK7 343-1 EX20-0XE0 in my catalog, but not 6GK7 343-1 EX21-0XE0, which is the module I have in my hands.
Any help would be appreciated.
Phill
Hey Phil,
Use the attached file to import the module data into HW Config (unzip first).
HW Config
-> Options
-> Edit Catalog Profile
-> Profile
-> Import...
-> (enter the name of the attached file)
-> search for your module under:
SIMATIC 300
CP-300
Industrial Ethernet
CP 343-1
6GK7 343-1EX21-0XE0
V1.0
...You're welcome.
I am using TIA Portal 14 and I cannot download to 6AV2 124-0UC02-0AX1 which is a TP1900 Comfort as I do not have the Hardware file for the device...
2,368
Hello, I am quite new to use this enviroment for programming PLC and I have big problems to find out, how to download hardware updates in this...
18,254
I am currently working on a SLC 5/05 project (I don't do a great number of these). I need to add a 1746-NO8I module, but RSLogix v6.00.00 I/O...
3,722
Hello guys, I've been using STEP 7 v5.3+HF2. I tried to open one STEP 7 project that was sent to me. When opened, I saw the windows "Modules...
6,915
Hi, I am using step 7 v5.4 SP2. My available cpu is 6ES7 414 4HJ04 0AB0 V 4.0.9 but in hardware catalog v 4.0 is available. therefore in...
23,953
