Step7 hardware catalog update
agha77
Aug 2007
Abudhabi
I am using step 7 v5.4 SP2. My available cpu is 6ES7 414 4HJ04 0AB0 V 4.0.9 but in hardware catalog v 4.0 is available. therefore in downloading message comes that your offline and online CPU are not matching.
I have update catalog online also but no use.
Please help me.
Thanks,
Best Regards,
Agha
Sounds like you are confusing online "PLC" with Online "net". The message from the hardware manager that you offline and online hardware is different is from the hardware config in the PLC (somewhere in system DB's?). The only way to get rid of that is to download hardware manager to PLC or upload station to project.
The hardware manager can get an updated hardware catalog from siemens. This is done from the HW manager. This usually includes the files needed for new siemens processors, IO, etc...
You can download Hardware Updates from Hardware Manager via the Internet.
1. Close down all editors except Simatic Manager.
2. Open Hardware Manager.
3. Select Hardware updates.
4. Download Updates (Execute Button).
5. Then Select ALL & Install.
6. Step 7 will close notify that it will close down. It will install Hardware.
7. Relaunch Step 7 and checkout new stuff in Catalog.
Nick
G120 CU250S-2DP does not appear in the hardware catalog of the simatic manager step7 v5.5. I upgraded to sp4, I did hardware updates, but still...
3,231
Hello, I would like to use a ET200S module but it is not yet listed in my catalog (current modules version 08.2005). Is it possible to install a...
6,923
Hi everybody, Does anyone know how to upload hardware configuration from PLC to PC in SIMATIC STEP7. I'am using S7-400 does it make the plc stop...
8,347
If I change the hardware configuration of a Simatic S7-400 PLC and perform a download in order to add new slaves to the profbus, does this...
4,395
Hi all, just have a theory question here. Using step7 5.5. I upload the hardware configuration from a dp or pn network that i do not have the...
3,178
