Update Hardware catalog in Step7
Garcia
Apr 2006
Pittem
37
Hello,
I would like to use a ET200S module but it is not yet listed in my catalog (current modules version 08.2005). Is it possible to install a more recent HW catalog in the HW config tool? I use Step7 V5.3 + SP3 Revision Level K5.3.3.0
Thank you!
First switch catalog to Standard profile. If module doesn'n appear in the catalog, you can download update from internet. Select Options>Install HW updates in HW Config menu, then select needed updates and install them.
Hello, I am quite new to use this enviroment for programming PLC and I have big problems to find out, how to download hardware updates in this...
18,257
Hi, I am using step 7 v5.4 SP2. My available cpu is 6ES7 414 4HJ04 0AB0 V 4.0.9 but in hardware catalog v 4.0 is available. therefore in...
23,957
I am using TIA Portal 14 and I cannot download to 6AV2 124-0UC02-0AX1 which is a TP1900 Comfort as I do not have the Hardware file for the device...
2,368
I am currently working on a SLC 5/05 project (I don't do a great number of these). I need to add a 1746-NO8I module, but RSLogix v6.00.00 I/O...
3,723
Hello guys, I've been using STEP 7 v5.3+HF2. I tried to open one STEP 7 project that was sent to me. When opened, I saw the windows "Modules...
6,916
