CU250S-2DP not in hardware catalog of step7 v5.5
Kataeb
Jan 2007
www.livelovelebanon.com
636
G120 CU250S-2DP does not appear in the hardware catalog of the simatic manager step7 v5.5. I upgraded to sp4, I did hardware updates, but still not showing. What can I do? Thank you
Even though this shows the DriveES version- you can still install a standard CU250s gsd and use Starter to configure drive.
hello friends i have siemens sinamics G120 drive when i start the motor from push button from off position the faults A7994 IS appeared every...
2,036
Dear Team, I need to increase the maximum speed of my drive upto 60 HZ. and sadly im stuck with some parameter. Below parameters are already...
3,267
Hi everybody. Today I need to program tow DI s for the Siemens CU250S-2 DP drive to act to stop the drive in the + and - directions when they hit...
3,378
Can anyone tell me how to read the status of control unit inputs in step 7. I am using a standard telegram 20. The communication is working...
1,612
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
170
