sinamics cu250s 2 pn
mick1985
Feb 2014
Barnsley
Can anyone tell me how to read the status of control unit inputs in step 7. I am using a standard telegram 20. The communication is working fine.....i can start and stop the drive etc i just nee to read the status of the on-board control unit inputs
hello friends i have siemens sinamics G120 drive when i start the motor from push button from off position the faults A7994 IS appeared every...
2,046
Dear Team, I need to increase the maximum speed of my drive upto 60 HZ. and sadly im stuck with some parameter. Below parameters are already...
3,303
Hello sameone have Beckhoff PLC Siemens Sinamics V90 configuration example?
126
Hello, I use a Siemens Sinamics G120C inverter in combination with a S7-1200 cpu. I use the Main Setpoint with the Providrive option and send...
813
Hello to all, I have a STEP 7 project (v5.6) with S7-400F CPU and Sinamics S120 drives with CU320x2PN (ord. nr. 6SL3 040-1MA01-0Axx). I need to...
991
