Kataeb Member K Join Date Jan 2007 Location www.livelovelebanon.com Posts 636 Oct 15, 2014 #1 G120 CU250S-2DP does not appear in the hardware catalog of the simatic manager step7 v5.5. I upgraded to sp4, I did hardware updates, but still not showing. What can I do? Thank you
Kataeb Member OP K Join Date Jan 2007 Location www.livelovelebanon.com Posts 636 Oct 15, 2014 #3 i did import it but no result. the scout is version V4.3.1.1, could this be a problem?
JRW Member Join Date Jun 2002 Location South Carolina Posts 2,315 Oct 15, 2014 #4 Yep. That's important to mention Scout 4.3 doesn't support cu250s
JRW Member Join Date Jun 2002 Location South Carolina Posts 2,315 Oct 15, 2014 #5 Even though this shows the DriveES version- you can still install a standard CU250s gsd and use Starter to configure drive. Last edited: Oct 15, 2014
Kataeb Member OP K Join Date Jan 2007 Location www.livelovelebanon.com Posts 636 Oct 16, 2014 #6 any Starter version will work? or we have to go for Starter v4.4?
JRW Member Join Date Jun 2002 Location South Carolina Posts 2,315 Oct 16, 2014 #7 For firmware 4.7 use Starter 4.4. I use DriveES with Starter 4.3. But I use fw 4.6 in cu250s
Kataeb Member OP K Join Date Jan 2007 Location www.livelovelebanon.com Posts 636 Oct 17, 2014 #8 thank you
