S7 indirect addressing LAR1 problem
baselch0
Jul 2010
Basel
27
Hi all,
I need to move in the same DB 32 bytes from DBB00-DBB31 to DBB32-DBB64, so I have tried to write a simple code using the indirect addressing, but when the FC is performed the CPU goes to STOP with the following error
where I am being wrong???
I'd like make a copy of the data inside the DB without using SFC20 [BLCKMOVE]
I attach the file zip program saved as library.
Thanks a lot
You need to pass the start address as a pointer, not a byte.
You will need to open the correct DB inside FC1 as well.
Howdy folks, I am an Allen Bradley guy currently living in an Emerson world. Working with Rx3i on PacSystems Machine Edition v. 9.6? i think...
623
Hello, I'm very new to programming with absolutely zero schooling in this field and pretty hands off training in my new role, it's been fun...
670
Hello Friends, I am trying to index M Bits, however GX Works2 is not allowing it with following message. https://ibb.co/zPcqj6M...
1,383
Hi All, which the best way to do the indirect addressing in an optimize DB? Ccurrently this is my partial code inside an FB...
2,277
Hey everyone, Just used the PLC5/Logix migration utility to convert a program, and while addressing the PCEs, I noticed a lot of errors for "XIC...
1,987
