S7 instruction
bdanelon
Oct 2003
I was wondering what i could do for a limit test like rockwell in the S7 world. I need to compare 2 Dints to another Dint
Either code FC3 as below and use FC3 when a limit is required, or use the logic from FC3 in your ladder as required:
That won't perform exactly like a Rockwell LMT instruction. The LMT can be true inside a range or true outside a range. The inside a range case is like the S7 FC3, where the lower limit is less than the upper limit. With the LMT if the lower limit is greater than the upper limit you have the outside a range case.
Keith
Hi all. Never really noticed, but I started double checking operands in the CPT instruction. I found if I have the expression N7[37,1] - N7[35,1]...
107
I'm trying to dig to the source of a minor "recoverable" system fault throwing a fault light on a machine that has been confusing my operator...
114
122
Does this instruction calculate values during a single scan, or does it require number of scans based on element count in the array? For Example...
129
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
307
