S7:Local Memory/Pointer question
STL???
Sep 2005
UK
879
Hi again,
I'm trying to understand whats going on in code below but i've never worked directly with Local memory and have been warned to be careful when doing so!!
One thing i'm not clear on is this part:
M001: LAR1  P##Matrix;
L 0;
T LB [AR1,P#0.0]; // Matrix loeschen
is #Matrix used to store the result of the Compares of #IN_1 to #IN_8, but initialised first in the above snippet?
Not speaking any German doesn't help the cause to much either!!:unsure:
Thanks again!
STL
FUNCTION "Enter Program Mask" : VOID
TITLE = Programmmaske Einlesen
// PRG-MASK
VERSION : 0.0
VAR_INPUT
ERST : BOOL ; // ERST
IN_1 : BOOL ; // IN-1
IN_2 : BOOL ; // IN-2
IN_3 : BOOL ; // IN-3
IN_4 : BOOL ; // IN-4
IN_5 : BOOL ; // IN-5
IN_6 : BOOL ; // IN-6
IN_7 : BOOL ; // IN-7
IN_8 : BOOL ; // IN-8
END_VAR
VAR_TEMP
Adresse : DWORD ;
Matrix : BYTE ;
ZW_Speicher : DWORD ;
END_VAR
BEGIN
NETWORK
TITLE = Init Adressdaten
AN #ERST; // 1. FB Aufruf
JC M001; // nein, dann weiter
L 0;
T DBB 82; // Zeiger Datenablage auf 0
T DBB 1000;
L 0;
NETWORK
TITLE =Kontrolle Anzahl Eintraege
L DBB 1000;
L 40;
>I ;
JCN ok;
CALL "STP" ;
ok: NOP 0;
NETWORK
TITLE =Matrix einlesen
A #IN_1;
= L [AR1,P#0.0];
A #IN_2;
= L [AR1,P#0.1];
A #IN_3;
= L [AR1,P#0.2];
A #IN_4;
= L [AR1,P#0.3];
A #IN_5;
= L [AR1,P#0.4];
A #IN_6;
= L [AR1,P#0.5];
A #IN_7;
= L [AR1,P#0.6];
A #IN_8;
= L [AR1,P#0.7];
NETWORK
TITLE = Maske speichern
L DBB 82; // 1. Zieladresse + Offset
SLW 3;
T #Adresse;
LAR2 ;
L LB [AR1,P#0.0]; // 83.0
T DBB [AR2,P#83.0]; // Adresse
L DBB 82;
INC 1;
T DBB 82;
NETWORK
TITLE =Abfrage 1 einlesen
L DBB 1000;
INC 1;
T DBB 1000;
SLW 4;
LAR2 ;
L P##IN_1;
T #ZW_Speicher;
LAR1 P##ZW_Speicher;
L LW [AR1,P#2.0];
T DBW [AR2,P#1000.0];
NETWORK
TITLE =Abfrage 2 einlesen
L DBB 1000;
INC 1;
T DBB 1000;
SLW 4;
LAR2 ;
L P##IN_2;
T #ZW_Speicher;
L LW [AR1,P#2.0];
NETWORK
TITLE =Abfrage 3 einlesen
L DBB 1000;
INC 1;
T DBB 1000;
SLW 4;
LAR2 ;
L P##IN_3;
T #ZW_Speicher;
L LW [AR1,P#2.0];
NETWORK
TITLE =Abfrage 4 einlesen
L DBB 1000;
INC 1;
T DBB 1000;
SLW 4;
LAR2 ;
L P##IN_4;
T #ZW_Speicher;
L LW [AR1,P#2.0];
NETWORK
TITLE =Abfrage 5 einlesen
L DBB 1000;
INC 1;
T DBB 1000;
SLW 4;
LAR2 ;
L P##IN_5;
T #ZW_Speicher;
L LW [AR1,P#2.0];
NETWORK
TITLE =Abfrage 6 einlesen
L DBB 1000;
INC 1;
T DBB 1000;
SLW 4;
LAR2 ;
L P##IN_6;
T #ZW_Speicher;
L LW [AR1,P#2.0];
NETWORK
TITLE =Abfrage 7 einlesen
L DBB 1000;
INC 1;
T DBB 1000;
SLW 4;
LAR2 ;
L P##IN_7;
T #ZW_Speicher;
L LW [AR1,P#2.0];
NETWORK
TITLE =Abfrage 8 einlesen
L DBB 1000;
INC 1;
T DBB 1000;
SLW 4;
LAR2 ;
L P##IN_8;
T #ZW_Speicher;
L LW [AR1,P#2.0];
END_FUNCTION
Yes you are correct. The initialisation to zero is redundant really as each bit of the variable #matrix is assigned later on. The only time the assignments will not be executed is if DBB1000 gets greater than 40 in which case the plc is put into stop anyway.
Hi Simon,
Thanks for confirming that, This FC is part of the same program as my previous thread, Funny thing is in this particular program it doesnt look like it does a great deal and nothing is executed using the DB addresses that are being pointed to!
I've been tasked with stripping out all the redundant code from this OEM (one program caters all) Project for our Maint crew.
Thanks again
Hello Guys! Another S7 question.... I've been having som strange problems for time to time with local memory in the S7 plc's. Especially with...
28
12,113
Hey guys. As the title suggests, I need to configure a Danfoss Aquadrive FC202 inverter, so that its logic inhibits the local command when the...
52
Is there a way to add a local message display to Studio 5000 View Designer? If its there, I’m not finding it. I have used them in older versions...
420
Hi, I'm trying to export data from a DataGrid to Excel using VBA, but I'm getting an error "Object doesn't support this property or method". The...
86
So our Powerflex 525's are set up to allow REMOTE operation from PLC through network. But if network is lost we want to be able to run in LOCAL...
577
