S7 - Multiplex Variables in ProTool Pro
RMA
Sep 2004
North of Hamburg, Germany
2,052
I've found the Multiplex Variable function in ProTool very useful (even if it did take me an age to learn how to use it - typical Siemens!), however, I never did manage to find a way of multiplexing output signals - for example the output of a push button on the screen to operate Relay x in Module nn, where nn is the current picture's index number.
I solved the problem simply by setting a Bit in a DB and then scanning the DB with an FC using the index number to identify the required module. It works, but it's not very elegant and it doesn't make it any easier for somebody else to maintain the stuff later on.
Does any body know definitively whether it is possible to directly multiplex the output from a button in this way? Or, alternatively, can anybody state definitively that it's not possible, so that I stop wasting time trying to fathom out how to do it!!!
Does anybody know if there's any way using Cut&Paste or similar techniques to speed up the generation of Multiplex Variables? I need to create the...
5,856
WinCC Pro V15.1 with CPU 1516-3 PN/DP As always , thanks for the amazing help, you guys are awesome. See the link below as a reference...
24
11,320
I have a project where I need to drive a dozen 7-segment LED displays from values of 0-9. Initially, I was doing to use panel mount digital volt...
17
7,784
I have a application with about 15 roof fans that are bel driven and in hard to reach areas. We are looking at softstarts for these such as the AB...
1,711
Hi I have a screen which I am multiplexing tags from a DB which is made up an array of structs (udts) (item1,item2 etc) I need to have an off/on...
3,786
