S7: Open Tcp/Ip Communication
pethoek
Apr 2009
Järbo
105
Have a question i'm struggeling with.
In my Project i use the blocks TCON, TDISCON, TSEND, TRCV to establish a Tcp/Ip Connection to third party device. This works excellent.
Problem occurs when i change remote IP-Address in my HMI and try to connect to a device that does not excist. This will cause the TCON block to be busy and status code 16#7002
Intermediate call (REQ irrelevant), connection being established
Because of this, new subsequent Connection attempts will fail even with correct IP.
I have also waited for a long period of time but the attempt does not seem to time out.
How do i cancel/abort this. I have tried to use disconnect (TDISCON). On communication blocks there usually is a COM_RST input that i can't find on the TCON block.
Anyone know how?
As you write it, the connection not available when you start TCON ?
In that case, I would guess you that you would have to wait for the result from TCON going BUSY=FALSE, DONE=FALSE, ERROR=TRUE.
Only then can you try another TCON attempt.
I would guess that you dont have to use TDISCON.
I have only had one project with the open TCP blocks, so I dont have much experience.
But as far as I remember, the ERROR would come on almost instantly.
Repeat:
What CPU and Firmware version is it ?
I'm using IM151-8 PN/DP Version 3.2
Establishing Connection for "minutes" don't feel right, right?
Seem like it nevere times out. Maybe the support has to answer this one.
I would like to communication with application installation in my printer server via TCP port 5450. i.e ., 71.16.40.200:5450 . How can i write...
443
Hi guys, I replaced proface him by new one and download the program from cf to display. Screen showing normal but I am facing TCP Connection...
1,841
I'm having problems with tcpClient's and tcpRead's connection handle. I recieve TCP_OPEN_ERROR(Could not open tcp server/client) for tcpClient and...
2,666
hi All Can you please help me to find the right software to open Zip backup of 434 12A PLC? Any major steps I need to know when opening? Regards
92
