S7: Pointer offset as variabel
It can be done like this
Code:
L     P#6.0                       // Load ACCU 1 with pointer value.
      T     MD     2                    // Transfer pointer into MD2.
      OPN   DB     1                    // Open datablock 1
      L     10
      T     DBW [MD 2]                  // Transfer value 10 to db1.dbw6
      L     P#2.0                       // Increase pointervalue in md2 with 2 bytes
      L     MD     2
      +D
      T     MD     2
      L     25
      T     DBW [MD 2]                  // Transfer value 25 to db1.dbw8
See the line 3 below the one you circled.
+AR1 P#2.0
This is changing the offset by 2 bytes, or the next word.
3 lines before the circled code, is where AR1 is originally set
LAR1 P#DBX0.0
If you want to vary the start point, you could use the +AR1 instruction after the LAR1 instruction and use a variable to do the offset.
i.e. prior to the code you can see have something like
L 2 <== could be variable
SLD 3
T MD500
Then after the LAR1 put
L MD500
+AR1
The variable name suggests you are looping through a number of reals yet you are loading/transferring words - might be a bit confusing in the future.
Hi again.
It's a cut from other program... and of coarse it will be changed to "No_of_Words"
I try to make the same function as TI505 - MWI Move With Index
Do you require two indexes, one for the source and one for the destination ?
What format do the indexes take, ints specifying the byte offset or pointers so you can specify DBW60 (for example) as the parameter ?
Do you require two indexes, one for the source and one for the destination ? Yes, just what i want
fx. 60 for "read from DB60" and 61 for "write to DB61"
What format do the indexes take, ints specifying the byte offset or: Yes, like offset from DB62.dbw0 Same offset for both indexes.. :p
Wow, Siemens must be proud of the URLs, they are sooooo long
http://www.google.com/url?sa=t&sour...Ve0ZBJ9wYLtAcLcRg&sig2=dNNhnQHStTxI_LXW6iqcjw
On page 6-104 the MWI instruction clearly shows that there is a source pointer, destination pointer and a count.
On page 6-90 there is the MOVE instructions that has a pointer and index for both the source and destination as well as a count.
If Bill is trying to emulate the MOVE instruction then one more parameter would be needed to scale the index into bit, byte, words and dwords offsets.
Code:
FUNCTION FC 1 : VOID
TITLE =
VERSION : 0.1
VAR_INPUT
  i_DB_Read_from : INT ;
  i_Offset_read : INT ;
  i_DB_Write_to : INT ;
  i_Offset_write : INT ;
  iNoofWords : INT ;
END_VAR
VAR_TEMP
  iLoopCount : INT ;
  iDB : INT ;
END_VAR
BEGIN
NETWORK
TITLE =
      L     #i_DB_Read_from;
      T     #iDB;
      OPN   DB [#iDB];
      L     #i_DB_Write_to;
      T     #iDB;
      OPN   DI [#iDB];
      LAR1  P#DBX 0.0;
      L     #i_Offset_read;
      SLD   4;
      +AR1  ;
      LAR2  P#DIX 0.0;
      L     #i_Offset_write;
      SLD   4;
      +AR2  ;
      L     #iNoofWords;
LA:   T     #iLoopCount;
      L     W [AR1,P#0.0];
      T     W [AR2,P#0.0];
      +AR1  P#2.0;
      +AR2  P#2.0;
      L     #iLoopCount;
      LOOP  LA;
      SET   ;
      SAVE  ;
END_FUNCTION
Hello Folks! I have an application where I need to copy a string into various locations within a DB. So, I've set up a Function Block to accept...
4,986
I have a word in some DB which I want to load to AR1 and use as a pointer. In order to do this I need to write L DBxy.DBW xy SLD 3 LAR1 I...
555
I am trying to access the value of a pointer via OPC UA in Codesys. I can share it directly and in a struct but I cant access the value of it when...
1,631
Why does my deconstruction of the input pointer only work with its own instance DB not inside the multi instance FB...See .doc The pointer at the...
2,390
Hi All, in many library function of TiaPortal some data must be write using the pointer format........ eg.: P#DB90.DBX0.0 WORD 10 is it...
2,823
