s7-power off problem
necyil
Nov 2004
Turkey
102
Hello
I make a program for s7-cpu315.
When power off. all data are go zero.(0) I use some count.
like that
A I 12.0
CU "C17"
BLD 101
A M 113.0
L C#5
S "C17"
A "m114.0"
R "C17"
L "C17"
T DB12.DBW 0
NOP 0
NOP 0
Which kind of change i make?
Many thanks for helps
Necyil
Go to HardWare-configuration, select the properties of the cpu and choose the tab 'retentivity'. There you can make counters, timers, flags and DB's retentive you they will keep there value after power down.
Hello..I am new to Plc.I have Mitsubishi Melsec Fx3Ga-40MR PLC controlling a machine for packing powder.Currently the Plc has issue which power...
165
I have a 5069-IB16 card on a rack controlled by a 5069-L320ERS2 (Safety Controller). For whatever reason I am getting a voltage reading coming out...
162
We have a devicenet consisting of 15 PF755 drives in a centerline MCC, and on a separate trunk cable coming off the scanner, a single PF525 in a...
352
Hi all, I was looking over the internet on trying to find a way to get how long the PLC was powered off. I am using AB PLC L83ES with Studio...
2,444
Hi, I've seen this on many machines over the years. Usually on the main control panel there are two buttons, one for control power on and one...
2,273
