S7 Pulsing timer
kevbloke
Jul 2004
Kent uk
81
Hi all, I am wanting to pulse an inverter to drive 2 seconds on and 2 seconds off 20 times after my machine crashes and builds back a slug of packs. This is to dose packs through a barcoder.
I am using Step7 315 CPU. Is there an SFC timer or built in timer i can use to do this rather that setting and resetting lots of timers.
Many thanks
Kevin
Many thanks
Kevin
Bit x.7 of the CPU Clock memory is a 2 second pulse.
You will need some edge detection logic to get this going to ensure the first pulse is 2 seconds long, if it matters for your application.
Many thanks for the help chaps. Next question, is it best to pulse the speed reference or the start signal on the inverter?
Depends on how the drive is configured.
Speed reference will use normal ramp down, removing start signal might cause rapid stop/coasting/normal stop/etc.
There are plenty of examples on the internet of how to make an LED fade on and off in a sort of pulsating or breathing pattern, but these all use...
17
5,851
I would like to energize an output for say 3 seconds, and then de-energize for 3 seconds, and then re-energize for 3 seconds, and off again for 3...
2,145
I have device which pulses a NO contact when it is in alarm (roughly 2 second pulse every 15 seconds). I need to move a 3-way valve when when my...
2,550
Im running a few simple ladder programs in Simatic Step7. How do I pulse an input on and off so i can see its effect on the output. And also how...
1,668
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
93
