That's a pretty lousy alarm indicator...
Think about how you can tell when the alarm is on and off. When the alarm pulse turns ON, you have an alarm, but when it turns OFF, the alarm isn't necessarily gone. You have to wait 15 seconds to make sure it doesn't pulse again...
Here's one (of many) ways to do it:
| ALARM +---------+
|---]/[----------| TIM 1 |
| | 15 SEC. |
| ALARM TIMER
|---] [---+---]/[----(LATCH)
| LATCH |
| LATCH
|---] [--------------(VALVE)
Attempt at an explanation:
First rung:
When the alarm is OFF, TIM 1 starts timing. When it finishes, the TIMER contact on the second rung will open. When the alarm is ON, TIM 1 will not run, and therefore the TIMER contact on the second rung will remain closed.
Second rung:
When the ALARM input is ON, the TIMER contact will be closed, causing the LATCH coil to turn ON. The LATCH contact will keep the LATCH coil energized (ON) when the ALARM input turns OFF, because the TIMER contact is closed. Once TIM 1 finishes, the LATCH coil will turn OFF because the TIMER contact opens.
Third rung:
The VALVE output simply follows the state of the LATCH.
Get it?...
beerchug
-Eric
P.S. You can probably shorten the TIMER preset by however long the ALARM input is ON. The timer begins timing when the ALARM input turns OFF, therefore the ALARM input should turn ON again in roughly 13 seconds (based on your "
roughly 2 second pulse" statement). This will just let you know the alarm is OFF, as quickly as possible.
