theColonel26
My thoughts on slack for a wire that goes from one point in a panel to another point in the same panel is that there should be enough slack for the wire to lay in the bottom of the cable tray, even if it can't, because of other wires. So that is usually like 2-4in (50-75mm) of slack on each end, so like 4-8 total.
I have seen others that leave between 1 to 3ft of slack.
For the purposes of this thread we are not talking about cables that come in or go out of the box. That is a difference subject as they are not as easy to replace if you need to relocate something.
