S7 question : There are no parameter and local variables names available
arocon
Oct 2006
Dubai
171
I changed a counter in a function block in Simatic S7 program on offline. Then i saved and closed the function block and open the data block associate with that function block and i am getting the following alarm :
'There are no parameter and local variables names available because there is a time stamp conflict between the interface of the block and the description of the parameter and local variable.'
What to be done to get rid of the message.
Thank you
You need to recompile the datablocks. You could delete your datablock and then put the call to the FB in again. It will then ask you if you want to 'generate' your DB again.
OR, if you right-click on the Blocks folder from inside Simatic Manager you can choose something like "Check blocks consistency". then perform a Full Compile (can't remember exact wording) and that will sort it for you.
I have a question about parameter files in Factory Talk View Machine Edition. Can you pass placeholders in a parameter file like you can with a...
1,767
Is there a way to use a parameter file parameter in the goto-display button parameter file designation? I'm guessing this sounds confusing so...
18
8,079
Guys, I have various PowerFlex 40 in my facility that have this weird front panel. It only contains one button and a small electronic device...
3,755
I have 6 Siwarex U and I'm comunicating via SFC 58 and SFC 59. In SFC's what are parameter IOID means? Tnx.
3,673
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
173
