Lesa Member L Join Date Sep 2006 Location Novi Sad Posts 71 Oct 13, 2006 #1 I have 6 Siwarex U and I'm comunicating via SFC 58 and SFC 59. In SFC's what are parameter IOID means? Tnx.
stplanken Member S Join Date May 2006 Location Alberta Posts 56 Oct 14, 2006 #2 Lesa said: In SFC's what are parameter IOID means? Click to expand... If I recall correctly, it must always be the value b#16#54 for the Siwarex U modules (that's how I have set it up in my code).
SimonGoldsworthy Member Join Date Mar 2005 Location England Posts 1,078 Oct 14, 2006 #3 IOID is the identity of the address area. B#16#54 = Peripheral input (PI) B#16#55 = Peripheral output (PQ) If you put your pointer over SFC59 and press F1, the Step7 help will be shown and gives the above information (and more).
Lesa Member OP L Join Date Sep 2006 Location Novi Sad Posts 71 Oct 14, 2006 #4 SimonGoldsworthy said: If you put your pointer over SFC59 and press F1, the Step7 help will be shown and gives the above information (and more). Click to expand... Thank you for that extraordinary information.
