S7, SFB4 IEC TON Question
Feb 2008
Walnuc Creek, CA
31
Hello,
I'm trying to use the IEC timer, SFB4, for the first time and it seems like it's not working properly.
I've uploaded a picture of the timer, showing the inputs/outputs to the function block. As soon as the IN input turns on the count from ET immediately jumps to the time PT, and the output Q turns on.
Does anyone know what could be the problem?
Thanks.
Hello! I have used two instances of the iec function block SFB4. They are defined as STAT instances within a calling function block. The presets...
1,607
Hi, I have a simple function block that does not function when I use multi instance SFB4 IEC Timer On Delay. I could not attached a zip of the...
9,089
Hi All I managed to use SFB4 in a FC using the IN_OUT interface, but I would like to improve if possible. Can I determine where the "timer area"...
3,148
Hi! Is it possible to declare several SFB4 (TON) in a UDT and then create several DB of type (from our UDT)? I was hoping not to have them...
2,216
If I want to force a TON (SFB4) to be complete can I use a one-shot to initiate a move where I will take the PT value and place it in the ET...
4,544
