SFB4 (iec On Delay) does not count time
Feb 2008
Skelleftea
Hello!
I have used two instances of the iec function block SFB4. They are defined as STAT instances within a calling function block. The presets are also STAT variables with datatype Time.
However, as soon as I activate the IN (input) of the SFB4, instead of seeing the time count up to the preset and then set the Q output, the output goes high at once. Not counting time.
I run this in the S7-PLCSIM simulator of version 5.3SP1. I have not had the ability to test on a real machine so far.
A bug in the simulator? Or have I ovelooked something?
There have been at least one problem with the IEC timers not working with PLCSIM and certain versions of Windows.
There is a hotfix for this for PLCSIM v5.3 SP1. But you cannot download it from Siemens. Maybe someone still has it ?
Hi, I have a simple function block that does not function when I use multi instance SFB4 IEC Timer On Delay. I could not attached a zip of the...
9,093
Hello, I'm trying to use the IEC timer, SFB4, for the first time and it seems like it's not working properly. I've uploaded a picture of the...
3,162
Hi All I managed to use SFB4 in a FC using the IN_OUT interface, but I would like to improve if possible. Can I determine where the "timer area"...
3,150
Hi! Is it possible to declare several SFB4 (TON) in a UDT and then create several DB of type (from our UDT)? I was hoping not to have them...
2,218
If I want to force a TON (SFB4) to be complete can I use a one-shot to initiate a move where I will take the PT value and place it in the ET...
4,546
