S7 TIA Portal: Trying to use PLCSIM - Software Licence expiry?
Mas01
Oct 2020
Leicester, England
1,109
Hi
I used to be able to launch PLCsim without any problem.
Now it tells me " STEP 7 Professional Licence is required to simulate this PLC"...
However, I do have a STEP 7 Professional licence - when I go to Help | Installed software I get a box that confirms it....
Any ideas why it thinks I don't have a licence?
That shows you have the software installed, open Automation License Manager, that's where your license is stored.
Maybe you had activated the trial period ?
Thanks, when I open the ALM, this is what I see.
Should a list of the active licences appear here?
Browse to the C: drive via the tree on the left.
If you have expired trial licenses they will also be shown.
Hang on - the ALM says I have "STEP 7 Basic", but the TIA Portal (Help | Installed Software) says I have STEP 7 Professional".
I'm confused.
STEP7 Basic only includes S7-1200 PLCs and BASIC HMI's.
I dont know if it includes PLCSIM for S7-1200. Probably not.
I'm confused.
TIA allows you to install the full package.
It checks for the license when you try to use a PLC, a HMI or a software package.
Today I clicked on a Unified Panel, and TIA told me that I dont have the license for that.
Thanks again.
At the moment, I can only conclude that I had a trial version of PLCSim, but SOMEHOW it was working with my STEP 7 Basic licence.
Maybe you're right @JesperMP - the PLCSim trial licence has expired and it won't work without a Professional LIcence.
What a pain in the wotsits!
If you did activate the trial license, then it would show in ALM as an expired trial license.
When you try to start a PLCSIM instance, do you get a pop-up asking you to install a license or activate the trial license ?
Thanks for trying to help me out mate.
When I launch PLCSIM, I get the error message as shown in post #1.
I have a s7-1200 CPU, by the way.
2 comments:
1) There's no way to install just Step 7 Basic these days. The install disc includes step 7 basic, professional, most of the different WinCC options, safety programming, etc. PLC sim is a diff disc tho, for some reason.
2) In the original screenshot, I see what looks like a simulated 1200, a simulated 1500, and a simulated 1200. My understanding is that you can simulate 1200's with a Step 7 basic license (like you have) and 1500s require the Professional license, just like the error says. Swap simulation 2 to be a 1200 and you should be good to go.
2 comments:
Cheers for this mate. You may be on to something. To you , is it the middle instance that looks like a simulated 1500? By virtue of the circled icon being the same as the 1500 icon in the right-hand margin thing? As yet, I don't know how to delete instances...can you help me with that? Thanks
If you poke around under "live instances" on the right side, I think you'll be able to manage the active simulations
UPDATE: I installed PLCSIM Service Pack 1, based on a suggestion from the Siemens PLC forum.
I now SEEM to be making some headway, but I don't understand why the PLAY button is greyed-out (when PLCSIM used to work for me, I used to press PLAY and then the "live" values of tags would be displayed in the Modify column).
Any ideas on this?
UPDATE: I fished around and the PLAY button is selectable now. (y)
(Although it looks like I've reached the row limit, but that's a different problem)
I'm trying to install TIA portal V13 SP1 on my computer. The system crashes and exits as soon as I try to creat a new project Can anybody help...
2,845
2,538
249
Hi guys , I'm new with Allen Bradley, but I have experience with Tia portal (s7 1200 ,s7 1500) I want to convert my project from Tia portal to...
205
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
169
