S7 TIA Portal - which connection option to choose for PLCSIM?
Mas01
Oct 2020
Leicester, England
1,109
I want to use PLCSIM because the hardware I was working on has now been delivered to customer.
Which option do I choose from this drop-down menu to establish a connection?
p.s. I like the site upgrade - much more like what I'm already used to - cheers to Admin for that.
What have you tried? I'd expect either option to work in most situations.
PN/IE_1 Is the subnet under which you want to connect by. This is the routing, in exactly the same method as going online with an actual CPU
Anyone have much experience of using PLCSIM?
It just seems a bit ropy and the look and feel of it, seems like it was added onto TIA as an afterthought.
I keep getting this message - PLCSIM used to start up ok before. After pressing the SIM icon, I get this message after 10 minutes. Might need a reboot.
Not moved on to TIA V18 yet but previous versions of PLCSIM are not what I would call ropey, I use it on an almost daily basis.
UPDATE - after several reboots of software, I have the window I was expecting to see.
I saw some youtube videos using v15 of PLCSIM - If you're familiar with v15, you can see how the user interface is a lot different compared to v18 shown below..
Good to know. Have you got v18?
I really recommend making sure you have all the updates installed. PLCSIM V18 with no updates was a bit wonky. first gen of the new UI that combines PLCsim with plcsim advanced
Thanks, I'll check I've got the latest and greatest.
There's a nice PLCSIM manual built into "PLCSIM Advanced" - unfortunately, PLCSIM Advanced is only applicable to 1500's and ET200 PLCs (I've got a 1200).
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
171
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
378
Does anyone know why the connection interface is greyed out and says why I can only use Teleservice instead of the other options like PN/IE? I am...
270
How can make communicate between wincc scada tia v13 and modicon plc m258 without using opc server i found in tia portal v13 for wincc (...
1,446
Siemens question: If communication between HMI and PLC fails, how can I detect that in the HMI for multiple connections? Thanks Pavol
16
5,908
