S7300 And Mm440
ABDELAAL
Dec 2007
ALEX.
32
HI ALL ,
1-WOULD YOU PLEASE TELL ME WHAT ARE THE PARAMETERS OF THE MM440 TO BE CHANGED TO MAKE COMMUNICATION WITH S7300 313C 2DP ?
2-IF ANY OTHER THINGS I SHALL DO AFTER CHANGING THE PARAMETERS PLEASE TELL ME WHAT IT IS IT .
3-IS it right to vary the control word of mm440 by normal load and transfer ??
with regards
hi there
1)P700=6,P1000=6, P918=Profibus address which u have defined in hardware configuration
2)After changing parameters, just run it !!
3)Load transfer will work as good as SFC 15/14
There is a file MM440 parameters in download section of this site.
Under siemens folder
(Note:Liverpool is better then Arsenal)
thanks for help
dear manmeetvirdi ,
1-thank you for your reply . Parameters you have mentioned ,I've already entered it before you tell me ,but the MM440 didn't work properly.
Note:-
(n)not true. (no other club is better than ARSENAL)
with regards
hi Iam using s7300plc communicate with mm440 drive. the communicate with each other but some data are not comming in hmi(current )iam sending the...
3,473
How can I integrate my S7-300 Simatic with the IFM AS-i Master AC1335 and its slave IOs, such as 2411 and Airbox 2041, into Simatic Manager?
144
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
192
Hi guys, I'm having problems converting WinAC (WinLC RTF F application) to S7 300 project based on CPU 319F-3PN or S7 400/416F-3PN. The problem is...
629
Hi Any one here please helpmein simulation of s7 300 plc program with factory io. how to connect. plcsim 5 doesnot have option of s7 300 ..:
1,037
