S7300 Modbus communication with CP341 module?!
robertcer
Jun 2007
Novi Sad
16
Hi!
Does anybody know, if I can connect to 2 or more PLCs with one CP341 module?
I have connected with S7300 PLC (CP341 module) to Unitronics PLC, but I want to connect with this module to another plc... I used a modbus master...
Does anybody have an example of connection to more than one plc with one cp341 module?
If you mean more than multiple Unitronics as slaves, i don't see any reason why not. They should behave like any other chaind slaves. The CP341 documentation will assist you about the physical connections.
Hi, I got two questios: There are two slave devices(SEL-787) from which I should read data via MODBUS RTU. I checked SEL-787 manual and it says...
5,570
Dear All I have worked with MODBUS TCP and RTU many times and commissioned successfully. Here First time I m working with S7300 to establish...
3,201
How can I integrate my S7-300 Simatic with the IFM AS-i Master AC1335 and its slave IOs, such as 2411 and Airbox 2041, into Simatic Manager?
138
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
192
Hi guys, I'm having problems converting WinAC (WinLC RTF F application) to S7 300 project based on CPU 319F-3PN or S7 400/416F-3PN. The problem is...
629
