S88 Help
HenkieD
Jul 2006
Durbs
62
Hi All,
My company asked me to do the design for a couple of case packing machines.
I would like to use S88 because all machines are pretty much the same, sometimes the one has two infeed lanes, then the other one, etc...
I've been reading a lot about it (S88), but I am still a bit confused, secondally it's my first project with Rslogix 5K.
Can somebody explain me what the best way would be to structure it in Rslogix.
A typical machine has
- 2 infeed sections (1 pusher with two solenoids and each with position feedback)
- 1 lift table (liftmotor with brake and 3 positions)
- 1 discharge section (1 pusher with 4 solenoids for 3 positions, two strokes per case)
- 1 case table (1 lift cylinder with 2 solenoids and position feedback)
I've been working with only Siemens equipment for the last 15 years, this in combination with a first attempt to use S88 requires a little help.
Much appreciated,
Henk
S88 is a standard and everyone have a slightly different interpretation of it. If you are a ISA member you can download the S88 standard and read it. If you google 'S88 model' you can access quite a few whitepaper on implementing it.
I always use elements of S88 model that I found useful. Like grouping associated equipment/device into "control modules". Such as a flow control loop, temperature loops, etc.
Anyone have links to Siemens libraries for S88 state engine? I assume they have this for download somewhere...
603
Has anyone ever used the S88 batch standard in aWastewater treatment plant? References?
2,803
Hi all, For the sake of organization and consistency would it make sense to group devices found in the unit's control panel (E-stop/safety...
1,956
Hi I have a project where I need to use RSLogix 5000 I have only used Siemens and Mitsibushi for the last 5 yrs and don't have RS Logix My...
3,389
Hi Everyone, I was reading through a few books about implementing Batch Control particularly about the S88 standards. I am already very...
4,753
