Safety circuit OSSD
SD23
Jan 2020
Belgium
Dear all,
Is it permitted to wire a normal safety button in series with OSSD outputs? (And will it work)
OSSD 1 => NC contact 1 button => OSSD input 1 safety relay
OSSD 2 => NC contact 2 button => OSSD input 2 safety relay
Thanking you in advance!
Hi and Welcome to the Forum!
Let's start with this...
SD23 said:
...normal safety button...
Do you believe such a thing to exist?
If so, then what makes it Safety Rated?
Or...
Are you describing what you wish it to be?
If so, then is it really Safety Rated?
If it is not Safety Rated, then do you think it should be permitted in series between a Safety Rated Output Signal-Switching Device (OSSD) and its intended Safety Input device (Eg: Safety Relay)?
Also, what will "work" is not necessarily what will be "Control Reliable", in Safety terms.
Regards,
George
Yes this will work and is generally permitted--of course it depends on the details of your specific application. As technology advances, however, the idea of putting multiple safety devices in series is becoming outdated. The concern is "fault masking"--see post #8 of this thread for a basic explanation.
Thanks for all the answers.
@Geospark, I'm using a standard Schneider emergency button so that should be fine.
The faultmasking aspect is something to not neglect in further projects, thanks for the hint!
Hi all, I'm working on a safety circuit and had some question about fusing. Incoming supply - 120V/15A Power supply - PSL-24-060...
592
Is the mechanism that energize a safety relay, Inductive or Resistive? These are the terminals that are marked as A1 and A2 on AllenBradley, Pilz...
778
Does anyone here have experience with the new GuardLink safety relays? They look like a dream to troubleshoot and work with since its just a trunk...
1,216
Hypothetically we have a machine with safety door switch and a E-Stop. The operator places the work piece into the machine, the door is closed and...
20
7,351
In a new electrical cabinet we have to apply to safety level PLd. We have a circuit for direct online motors. We will be using two power...
2,187
