1. I have used a two handed start button's safety relay, as my reset for operators manually loading a machine's light curtain station. We had a ton of two handed start stations, and the physical placement would cause the operator to be in a safe position when starting the machine. The light curtain was redundant, and an addition to ensure the safety was broken the entire time they were reaching into the mill. It passed our own personal risk assessment.
2. A safety should stop potential energy. We don't kill power to drives because it kills them over time, but they have safety rated STO signals, robots are the same. There will also be inputs that have power, and stack lights typically have power in that scenario as well. If you trip that light curtain, and you can force stuff to move without resetting that light curtain...... It would be a red flag in my book.
I was trained in a time before safety PLCs. We couldn't "program safeties". We set up our safety's to kill all potential energy when entering a work envelope. Pneumatics dropped air, spring return valves kept valves open/closed, breaks on motors defaulted to engaged when power was lost for hanging applications, and all dangerous things were safe when we entered a work envelope.
After you read all of these, you should be good to go on making a decision.
Have fun.
The Law (code)
NEC, NPFA70, CEC
Adoptable Standards (suggestions, but you get sued regardless)
European Standards (EN/IEC):
• IEC 60204-1: Safety of machinery - Electrical equipment of machines - Part 1: General requirements
• IEC 61439-1: Low-voltage switchgear and control gear assemblies - Part 1: General rules
• IEC 61800-5-5: Adjustable speed electrical power drive systems - Part 5-5: Safety requirements
American Standards (NFPA, UL, CSA):
• NFPA 79: Electrical Standard for Industrial Machinery
• UL 508A: Standard for Industrial Control Panels
• CSA 22.2 No 14: Industrial Control Equipment
• UL 845: Motor Control Centers
• UL 508C: Power Conversion Equipment
• CSA 22.2 No 274: Industrial Control Panels and Assemblies
6. Additional Standard references.
ISO Standards:
• ISO 12100: Safety of Machinery - General Principles for Design - Risk Assessment and Risk Reduction: This standard provides a framework for risk assessment and risk reduction in the design and use of machinery. It outlines general principles and a structured approach to identifying and mitigating hazards.
• ISO 13849-1: Safety of Machinery - Safety-Related Parts of Control Systems - Part 1: General Principles for Design: ISO 13849-1 specifies principles for the design and integration of safety-related control systems in machinery.
• ISO 13850: Safety of Machinery - Emergency Stop Function - Principles for Design: This standard defines the principles for designing and implementing emergency stop functions on machinery.
• ISO 13855: Safety of Machinery - Positioning of Safeguarding Devices with Respect to the Approach Speed of Parts of the Human Body: ISO 13855 provides guidelines for determining the minimum safe distance between safeguarding devices and hazardous machine parts.
• ISO 14119: Safety of Machinery - Interlocking Devices Associated with Guards - Principles for Design and Selection: ISO 14119 outlines principles for designing and selecting interlocking devices used in conjunction with guards on machinery.
• ISO 14122: Safety of Machinery - Permanent Means of Access to Machinery - Various Parts: The ISO 14122 series covers requirements and guidelines for the design and construction of permanent means of access, including stairs, platforms, and walkways.
• ISO 13857: Safety of Machinery - Safety Distances to Prevent Danger Zones Being Reached by Upper and Lower Limbs: This standard specifies safety distances to prevent danger zones from being reached by the upper and lower limbs.
• ISO 16092: Machine Tools - Safety - Machining Centers: ISO 16092 addresses safety requirements specific to machining centers, including milling and turning centers.
• ISO 20607: Safety of Machinery - Instruction Handbook for Machinery: This standard provides guidelines for creating instruction handbooks for machinery, including information on safe use, maintenance, and troubleshooting.
• ISO 22400: Industrial Automation Systems and Integration - Key Performance Indicators (KPIs) for Manufacturing Operations Management: ISO 22400 is related to the monitoring and performance measurement of industrial machinery and systems.
• ISO 4413: Hydraulic Fluid Power - General Rules and Safety Requirements for Systems and Their Components: This standard outlines general rules and safety requirements for hydraulic systems used in industrial machinery.
• ISO 4414: Pneumatic Fluid Power - General Rules and Safety Requirements for Systems and Their Components: ISO 4414 focuses on general rules and safety requirements for pneumatic systems and their components in industrial machinery.
• ISO 13849-2: Safety of Machinery - Safety-Related Parts of Control Systems - Part 2: Validation: Part 2 of ISO 13849 provides guidelines for validating the safety-related parts of control systems in machinery.
• ISO 16092-1: Machine Tools - Safety - Part 1: General Purpose Machines: This standard addresses safety requirements for general-purpose machine tools used in various industries.
• ISO 16092-2: Machine Tools - Safety - Part 2: Numerically Controlled (NC) Turning Machines and Turning Centers: ISO 16092-2 specifically covers safety requirements for numerically controlled turning machines and turning centers.
