Safety signals
Plc_User
Dec 2005
Belgium
317
We have a remote cabinet with drives that have the Safe stop option : cutting of the 24V of the power stage cutts off the motor in safety cat 3. Can we use a wire in a multicore to transport the 24V for the cuttof of the drive in case also the 24 V that is always on is also in this multicore? Or do we have to use separate wires? I know that you can discuss about that, but what does the safety reglementation says about that?
The safety regulations BASICALLY say that any one failure should not cause a failure of the safey system. Therefore every thing possible should have redundancy (2 or more paths).
There are not any electrical codes (that I know of) that prohibit wires of the same voltage but different functions from being in the same cable.
If you look at the manufacturer's literature I think you will find that you have to use a seperate shielded cable to the safe stop input. If you use a multi-core then there is a danger that a short between cores can occur and hold the stop function on, this is not safe. For cat 3 you also need to ensure that the device switching the safety input is cat 3, such as a safety relay.
Hi I have a Redundancy Automation sytem with cpus 417-4H Siemens. in my Plant there are safety modules. I have a problem with saferty signals...
2,930
Hello All, After trying to transfer some field changes on the safety scanner microscan3, and verifying, the device is stuck at .... waiting for...
51
After some interesting conversation regarding the safety of emergency stops, I saw some posts talking about the safety standard conversation...
26
936
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
128
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
116
