SAIA driver
Axel24
Mar 2007
malmö
When i install SAIA programing software PG5 and try to go online it sais that driver not available, SCcomm.dll
any suggestions?
tanks
Regards
Axel
You need to set up your drivers, like COM1 Serial, etc..
Are you using a REAL serial port? Or a USB?
It is really quite straight forward, just look at your communications in the comms folder.
What is your version of PG5 ?
but aniway the main cause of it should be your firewall rules
Your topic is nearly old and I don't know if you fix your problem
I have a SAIA PCD-2 PLC that was configured by someone in Europe. There are various digital, analog inputs and digital outputs. My requirement is...
9,770
Would anyone know what software is needed to program a SAIA PCD1 controller? Or know where to find it online?
173
Questions about an old SAIA PLC type PLC is PCD4 - board RS422 (PCD7.F110) We sold a HMI to replace one but our HMI doesn´t communicate with the...
1,094
Hi there. I am trying to read time of day from a Modbus register in SAIA PCD3 however I have limited data about the point. It should be read as...
2,419
Good morning. I have SAIA PCD4 PLC system (kindly see the attached photo). I need to upload the program to be a backup in case of any...
3,710
