SAIA - Old PLC PCD4 doubt
Sep 2020
São Paulo
Questions about an old SAIA PLC type
PLC is PCD4 - board RS422 (PCD7.F110)
We sold a HMI to replace one but our HMI doesn´t communicate with the PLC.
In one of the PLC files it opened the Port by SASI command (see below).
$SASI
; Testo comunicazione VT
TEXT 1
"UART:9600,7,E,1;"
"MODE:SD0;"
"DIAG:F10,R1;" ; Flag 10-17/R 1
$ENDSASI
The SAIA protocol that our HMI has is S-BUS (datamode)
One possibilty that we see is use the PGU port (RS232) but is configured for P8 protocol.
My questions are:
1- I know by PG5 tool is possible to active the S-BUS, right ? If I change how I manage in this case the Eprom ? Or the CPU manage it automatcally ?
2- Will be becessary to change the SASI in this case ? I should remove it from the program ? and the same preview quation, What about the fthe Eprom ?
I hope you understand my questions and I appriciate so much if you could help me.
Thank you everybody.
Would anyone know what software is needed to program a SAIA PCD1 controller? Or know where to find it online?
163
Hi there. I am trying to read time of day from a Modbus register in SAIA PCD3 however I have limited data about the point. It should be read as...
2,393
Good morning. I have SAIA PCD4 PLC system (kindly see the attached photo). I need to upload the program to be a backup in case of any...
3,670
hi, i have a machine with SAIA model number PCD2.M5540. Recently i am facing issue regarding the run and stop mode. i tried setting the plc to...
1,828
I have a customer that wants a machine upgraded. It has a Saia PLC and they have a copy of the project. Could anyone please print this as a PDF...
1,443
