Saia MCD2 M150 software problem
Hans Sietsema
Sep 2012
Harlingen
I've got a Saia PLC and using PG5 software.
Now I want to connect to the PLC but I only received the .PDC and .5hw files.
Is there a way to get the get the software reverse the compiled PDC file so I can see and add new software.
I have the .pdc and .5hw files.
Hans
If this still is useful, I might be able to help you out. So you've uploaded the program from the PLC, and sit there with a .5hw file and a .pcd file?
If this is correct, you might be able to use the disassembler in Project Manager on the .pcd file. You'll only get the assembled code, though. Not any real definitions. but you will be able to read the function of the program, then the rest should be a breeze to figure out
Would anyone know what software is needed to program a SAIA PCD1 controller? Or know where to find it online?
171
Questions about an old SAIA PLC type PLC is PCD4 - board RS422 (PCD7.F110) We sold a HMI to replace one but our HMI doesn´t communicate with the...
1,090
Hi there. I am trying to read time of day from a Modbus register in SAIA PCD3 however I have limited data about the point. It should be read as...
2,400
Good morning. I have SAIA PCD4 PLC system (kindly see the attached photo). I need to upload the program to be a backup in case of any...
3,690
hi, i have a machine with SAIA model number PCD2.M5540. Recently i am facing issue regarding the run and stop mode. i tried setting the plc to...
1,840
