Saia PCD4 with EXOR terminal
G67hu
Oct 2007
Budapest
Hy Everybody!
I'm trying to use EXOR TextTerminal with Saia PCD4 PLC.
I use Deisigner 6.
Must in PLC set communications parameter, or what's is default?
Only PGU port is usable, or port1 to.
I'm trying different setup (speed, parity, bits, stopbits) in terminal, without avail.
I use cabel CA43.
Can anybody help me?
Hi
Saia pcd kommunication ports are by default disabled,except port0 (PGU port)which detects the P800 programming protocol, but may have been set up to an other mode. You have to check program to find out.
You enable ports (protocol,mode,baudrate,delay etc)in software (SASI text) or through PCD SW Configuration (SBUS PGU)
Does the EXOR TextTerminal support Saia SBUS (native Saia bus protocol(Datamode or parity mode) or P800 protocol? You must check that up. Also check cable.
Bardes
Questions about an old SAIA PLC type PLC is PCD4 - board RS422 (PCD7.F110) We sold a HMI to replace one but our HMI doesn´t communicate with the...
1,089
Good morning. I have SAIA PCD4 PLC system (kindly see the attached photo). I need to upload the program to be a backup in case of any...
3,679
Gentlemen, I am looking for some parts for a SAIA PCD4 system. If anyone has any of these parts for sale (new or used) please leave me a PM...
6,041
Hi with lot of negotiation with our plc contractor, they handed us source files which are in .src and .pcd file. They also handed over some dos...
2,887
Would anyone know what software is needed to program a SAIA PCD1 controller? Or know where to find it online?
167
