Do you have access to the system, the backup-files or just a printout of the system?
If you have access to the system and are able to connect you can choose between PBS-format (as I think you are referring to) and LAD when you are at “>”. This should give you the presentation in LAD for everything that is possible to show in LAD.
With backup-files I know that there exists software that can convert from SattCon to Simatic S7 if this would help. If that’s an option I can give you the name of the company.
With printouts I don’t know of any good ways to solve your problem.
Hope this helps
