SattCON PLC instructions
joaco1993
Sep 2014
newyork
237
Hi eveyone,
Im having some problem understanding some of the syntaxis used in this PLC, which is a really old one
Atached part of the program.
The thing I dont understand is the SSN and RS instruction. What is used for ??
If anyone could translate that into ladder would be great !
I already know what it means AD,OR,AP,RP but not SSN and RS and for what it is used.
Thanks!!
SattCon 31
I guess it's a SatCon 31 you've got there. I finally found a manual around in the archive.
AD
=And
SSN
=Set Skip Not, Jump forward to RS if previous is false (use SS if true)
OR
=Or
RP
=Right Parenthesis
AP
=AND left Parenthesis
SE
=Set
RS
=Reset Skip, jump is over if true
Se attachments for manual pages (you'll have to live with the swedish text though).
Edit: See links instead for full resolution (using imgbb.com)
http://ibb.co/hZ45sF
http://ibb.co/njzS6a
Hope it will be useful!
Hello, My task is to upgrade a control system based on SattCon OP45 PLC to a Simatic control system. I have some questions : 1- What is the...
1,464
We have a SattCon PLC. It looks like a single circuit board with a LCD display and membrane keypad that connects via a ribbon cable to a few I/O...
24
56,956
Hello, I am new to ABB PLCs. I have a file PLC3A.S_M, which is a SATTCON35 PLC Backup. Is ther anybody knows, Through which software(DOX5 /...
2,788
Hi, Currently, I am having a look at Sattcon PLC program. I need to find out the I/O configuration for this PLC like the Type of module in each...
2,511
T
what is the operating system for sattcon 31-90 and sattcon 60-50. what is the programming language for sattcon 31-90 and sattcon 60-50.
4,384
truwinjose
T
