SattCon PLC
SatCon 05
Hello i have to restart my Satcon 05 and in the manual it stands that i should press the cpu card button for 10 seconds but i wonder were that button are located? MVH Fredrik
Hi Fredrik
What model of SattCon05 do you have?
If it is a model with built-in keyboard, do the following:
Press 0 + ENTER - go to command level
In Command level
Press 1 + PROG - start program (0 + PROG = Stop program)
PLC in RUN -
Press QUIT - go to basic level
JERA
Dear experts, perhaps someone has encountered a similar problem.
The controller ABB SattCon S200 30/20 can not start and is in debug (pROBE) mode.
When I try to start the user program with mode-swith in any work position, I receive a message:
PLC is in debug mode (pROBE), on-line communication not possible
When the controller is turned on with mode-switch in position 5, which is intended for downloading the system program, diagnostics starts. All tests are OK.
After diagnostic finished the controller started download pSOS:
pSOS vectorable found at address=02418D00
pSOS+ 1.9-5 22-MAR-2004 14:04:13.89
Configuration: TFTPboot
Network Interface 172.16.0.0 <--Cannot open device
LOADER Test generated : 2-FEB-2003 21:01:24.65
LOADER started
TFTPserver started
My question is: how can I connect to the TFTP server and download the system program (pSOS)?
What I need for that?
Hi. i have a problem about ABB op45 scs45r system .
My have a old machine using ABB SCS45R PLC control system .Recetly suddenty could not run.When power on,it show "program stop" alarm lamp back of op45. Infront lcd display "RAM OK_".So no other work.
So.pls
Hi, we have a problem about to dowloading program from dox5 to op45. Can you help me please we have an in trouble
So.pls
Hi eveyone, Im having some problem understanding some of the syntaxis used in this PLC, which is a really old one Atached part of the program...
1,841
Hello, My task is to upgrade a control system based on SattCon OP45 PLC to a Simatic control system. I have some questions : 1- What is the...
1,464
Hello, I am new to ABB PLCs. I have a file PLC3A.S_M, which is a SATTCON35 PLC Backup. Is ther anybody knows, Through which software(DOX5 /...
2,790
Hi, Currently, I am having a look at Sattcon PLC program. I need to find out the I/O configuration for this PLC like the Type of module in each...
2,512
T
what is the operating system for sattcon 31-90 and sattcon 60-50. what is the programming language for sattcon 31-90 and sattcon 60-50.
4,385
truwinjose
T
