SCADA Citect - Creating Genie
Tim.K
Jan 2020
Kamloops
Hi all,
I am very new to Citect, and trying to make my own Genie.
What I have done:
Create my object and assign function -> On when " %Run_Status% = 1.
Made my own equipment type.
Under items, tag names are all -> {equipment.TAGPREFIX}_Run_Status or etc
Linked a Genie into Equipment type.
Under Genie Properties, Run_Status = {equipment.TAGPREFIX}_Run_Status
When I paste Genie on the graphic builder, it gives me an error "Operand Expected."
In Graphic Builder, {equipment.TAGPREFIX} does not transfer into my actual prefix, it stays how it is.
Anyone knows how to transfer {equipment.TAGPREFIX} into actual prefix?
Thanks!
Not 100% sure but "Run_Status = {equipment.TAGPREFIX}_Run_Status" probably needs something like:
Run_Status = {equipment.TAGPREFIX} + "_Run_Status"
This is the format I used for a genie
mnpr%nwp%_diff_volts
%nwp% is number of the unit i pasting on the screen
When you paste the genie you will be prompted to fill
in a value.
final is = mnpr123_diff_volts
I have no idea what you are talking about, but when I saw the word "genie", I thought of that genie game, where the guy can guess any celebrity, athlete, or character you are thinking of.
Hi everyone, I am trying to create a medium sized Citect SCADA project utilising a Control Logix PLC. I want to adopt good practice from the...
2,347
42
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
292
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
362
I am new to Citect SCADA and I am building the graphics for a page that will contain the control of a plant by a Kingfisher RTU. The project I...
272
