SCADA PcVue 10 - Start Network Command Error (1043)
ongzy
Dec 2010
Selangor
100
Error on start network command (1043)
I'm trying to link PcVue 10 to Saia Burgess PCD3.
Using Saia IP & Ethernet, both gave the same error.
Anyone encounter this before?
Yes. But ive forgotten how, so sorry. There is another alternative. We use modbus ethernet protocol instead of saia protocol. Hope this helps.
thanks for the answer.. already spent 3 days to try to solve it..
So, I need to update something in PcVue you mean?
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
48
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
66
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
40
70
So I'm pretty new around here but I come looking for advice or suggestions to research. Im the plant electrician/SCADA guy for a warer department...
279
