SCADA PcVue 10 - Start Network Command Error (1043)
ongzy
Dec 2010
Selangor
100
Error on start network command (1043)
I'm trying to link PcVue 10 to Saia Burgess PCD3.
Using Saia IP & Ethernet, both gave the same error.
Anyone encounter this before?
Yes. But ive forgotten how, so sorry. There is another alternative. We use modbus ethernet protocol instead of saia protocol. Hope this helps.
thanks for the answer.. already spent 3 days to try to solve it..
So, I need to update something in PcVue you mean?
46
So I'm pretty new around here but I come looking for advice or suggestions to research. Im the plant electrician/SCADA guy for a warer department...
237
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
64
Has anyone ever seen where you have a tag reading from the plc in scada. In this instance it's just a PEC, I set it up on one scada terminal and...
99
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
152
