scada to powerpoint communication
ashu31godbole
Feb 2013
harda
I am using wonderware intouch 9.05 and 10.0 ver.
suppose if i made a bottle filling plant in which a bottles are fastly moving and filled on conveyor under a tank (cyclic process), can i see same thing in Microsoft PowerPoint 2007 as we see in run-time mode (window viewer).
i am creating ppt to explain about scada
and wonderware....
i hope you got my question properly......
47
So I'm pretty new around here but I come looking for advice or suggestions to research. Im the plant electrician/SCADA guy for a warer department...
237
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
64
Has anyone ever seen where you have a tag reading from the plc in scada. In this instance it's just a PEC, I set it up on one scada terminal and...
99
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
152
