scada
What is it that you are actually trying to achieve? How long time period and how many values are we talking about?
The issue sounds quite interesting, but I highly doubt there would be any ready solutions for this kind of thing.
yes it is interesting..i am working on a project pipeline leak detection ..the project containing ultrasonic flow meter and plc ..i need to monitor any change for flow value and pressue ..the historical trend will show this but i need to make an alarm on changing time or specific variation time ..can scada do it ?
You are fingerprinting. That's a tough nut to crack. Sounds like you need to watch Ramp (or decay) Rate or 2 parameters and match that to your known "fingerprint" of a bad condition.
36
So I'm pretty new around here but I come looking for advice or suggestions to research. Im the plant electrician/SCADA guy for a warer department...
234
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
64
Has anyone ever seen where you have a tag reading from the plc in scada. In this instance it's just a PEC, I set it up on one scada terminal and...
99
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
152
