SCADALARM 6.0 sending email question
Apr 2011
Manila, Philippines
295
Hi!
I want to configure our SCADALARM to send an email when an alarm occur. I configured the email addresses of the receivers but I'm having a hard time in configuring the email tab in system parameters. I enable email, put my google account (for testing only) and put the smtp.mail.google.com as Email server. But when I tried to manually send email , no email was received.
Any suggestions? Thanks
Hello,
Three things.
1) smtp.mail.google.com I thought it was smtp.gmail.com.
2) GMail requires TLS/SSL. If "SCADALARM" does not support TLS/SSL, it will not work.
3) You normally have to specify the port numbers.
These are the settings I know work in PeakHMI.
The settings used for testing TLS/SSL with Gmail:
SMTP host: smtp.gmail.com
SMTP port: 465
Authentication: Autoselect
SSL-Type: Implicit (TLS Connection)
Priority: Normal
POP3 (if required)
POP3 host: pop.gmail.com
SMTP port: 995
Authentication: Login
I have inherited Invensys Wonderware SCADAlarm scheduling due to an employee leaving. I've learned enough to have a bit of knowledge, but have an...
1,377
Hi guys, I'm having a trouble now in SCADAlarm, When an alarm occurs it successfully call me through phone but the problem is it didn't speak...
1,394
Hi Guys, I would like to seek help for my task with SCADAlarm, I have to configure the app so that whenever an alarm occurs, an email will...
1,473
Can anybody please tell me why SCADAlarm 6.0 gives massage in system status like "An I/O device used by SCADAlarm failed" and in main window...
1,733
hi guys ,need help how to connect scadalarm on the RsviewStudio,will it support to start DDE...thanks..what is the Default DDE Application...
2,979
