scadapack 350 to wonderware
ygnm
Feb 2015
vicksburg, ms
85
ok fella's i have a question. i am trying to get data from a scadapack 350 in the field and use it on my wonderware. i can get data from it but it is in no way shape or form correct. i cant figure out what i need to change in order to or it to give me the real numbers. HELP PLEASE!!!!!!!!!!!!!!!:sick:
Might be sure your offset is correct. Also the MSB versus LSB may need changed.
I've got 16-bit data at address 40200 on a Schneider Scapack 350. I can grab the data over Modbus TCP using Kepware at IP 172.16.1.100. When I...
2,538
I am programming a SCADAPack 350 with Telepace Studio. I want to know if the logic in running the first scan and if the program is running...
1,262
Hi! I've got a customer that has several SCADApacks at remote sites and I need to make changes in their cellular network system. I have the .pia...
1,920
Hi guys, I'm working on a well pump that is supposed to use a PID loop to maintain system pressure through changing pump speed. I'm using a...
2,232
Looking at updating a small (1000 customer) water distribution system The main site has a ScadaPack 357 and there are 4 remote locations using...
2,063
