Scalance S602
Damain06
May 2015
Uitenhage
Good day all
I have a slight problem with a Siemens Scalance switch S602 that I need to configure.
I need to put a production line on our local server.
The production line is line the range
172.168.x.x
subnet 255.255.255.0
our local plant network is in the range
10.10.x.x
255.255.254.0
I am suppose to use a gateway setting of
10.10.x.y
I tried various configurations with the SCT software to set the scalance up to allow data flow from the external network to the internal network and vica versa. I am unable to ping any device on the internal network from the external network.
Any advice would be much appreciated.
Thanx in advance
Hi all, I'm having an issue with the setup of the NAT function of a Siemens S602 Scalance. I already have a working NAT functionality (see pic in...
2,949
Hi all, is there a way to remove a Scalance S602 in TIA V13/14? Whenever I try it I get the message that it's not allowed to remove security...
2,101
We are having an issue with some servers, with "Teamed NICs" is we plug one cable leg of the team into one switch and the other to another...
65
Hi all, I have some difficulties with programming a NAT config in my Scalance SC636-2C When programming the NAT-table i'm not able to reach my...
201
Can the XM408 Scalance Switch ( 6GK5408-4GP00-2AM2) be integrated into a Step 7 ( v5.6) project via Profinet so that we can read the switch...
1,281
