Scalance Switch Profinet Device Name
Automaquest
Jun 2019
North Carolina
I found two Siemens Scalance switches on the network using the same IP address (problem). Turns out they were configured as Profinet devices with the same device name in TIA portal in two separate projects. So I made them unique and reassigned IP's correctly. But I cannot imagine how the one switch got "downloaded" with the incorrect I/P address. Seems starting a PLC caused it to go out and reconnect (and "correct") the configuration of the wrong switch due to duplicate device names?
More or less, yeah. If a profinet device has a device name, it takes whatever IP it is given from the PLC. MY guess is that on one startup the PLC found one, and after a power cycle it found the other first, and then they both had the same config from the same PLC.
Static
They are setup static within the TIA Portal project configuration. It appears that the Profinet device name took precedence and overwrote the IP of one project from the PLC into the scalance switch associated with the other project's PLC.
Hello, I would like to be able to read useful information in S7 v5.5 about the status of the different ports on my Scalance switch; such as...
5,473
Dear All, I need information about how to communicate Wincc v7.4 scada with scalance xb205-3ld manage switch to check its communication port...
3,556
We are having an issue with some servers, with "Teamed NICs" is we plug one cable leg of the team into one switch and the other to another...
77
Hi all, I have some difficulties with programming a NAT config in my Scalance SC636-2C When programming the NAT-table i'm not able to reach my...
226
Can the XM408 Scalance Switch ( 6GK5408-4GP00-2AM2) be integrated into a Step 7 ( v5.6) project via Profinet so that we can read the switch...
1,301
