Scaling Analogue input TSX Premium
userxyz
May 2002
any
2,768
In a Siemens, when you read an analogue input from a standard modul you read in the range 0-27648 INT value.
What is the range in a TSX Premium programmed with PL7 ?
Thanks in forward,
Kind regards,
Gerry
Hardware conf
Okay, nevermind, I've found it.
Scaling can be done in de Hardware config and read the input can be found in the Variables table.
Kind regards,
Gerry
Thanks in forward,
Kind regards,
Gerry
369
Hello guys I am just wondering do I need to set up each channel configuration, including enabling the channel , ranging … if I have already...
2,019
There have been a number of posts asking about scaling so I thought this may help. The formula is: Out := ((Variable_In - ZeroIn) / (SpanIn -...
6,531
Hi all you gurus, I've got a CPU942b which is reading an analogue input, and scaling it, but I'm getting odd results. In short, what the code...
3,620
Hi, I have an application with a load cell where I need to log the load cell output, into a small/internal data logger. But I also want the...
1,721
