Hello Experts,
I am using Step 7 V5.5 Sp4 for my project. In my project, I was scaling 4-20mA signal to -180 to 180. As of now it sounds like a liner function but the customer has changed the specifications.
The signal which is available now is 4.11mA to 19.89mA and the range has changed to -152 to 180. For your reference I have attached the table.
As you can see from the table after 5.24mA the display value is not changing and it stays on -152. I have managed to write the code for this.
My concern is the positive side, as you can see after 19.56 mA the remote joystick position is changing in 0.5 degree but the actual display is changed by 1 degree.
As of now my scaling function is showing me the range from -152 to +175 but in actual it should show -152 to +180.
I hope I am making some sense.
Appreciate your comments/feedback.
Regards
Manoj
Regards
Manoj
