Scaling in Visual Basic...
userxyz
May 2002
any
2,768
I wrote this in VB:
Dim AI As Integer
Dim Range As Double
Dim Offset As Double
Dim Resultaat As Double
Private Sub Calc_Click()
AI = Inpu.Text
Range = Rang.Text
Offset = Offs.Text
If AI = "" Or Range = "" Or Offset = "" Then Exit Sub
Resultaat = (AI / 27648) * Range + Offset
Resu.Text = Resultaat
End Sub
I try to run it and get:
Member allready exists in a object module from wich this object module derives
This is my first programm in Visual basic btw...
Tnx for any help
The first thing I see is that you are comparing a double with a string value where you check to see if the text boxes are empty.
Try it this way
if inpu.text="" OrElse Rang.text="" OrElse Offs.text="" then Exit sub
This should also be the first line in your calc_click sub.
I am assuming you are using VB.net
Try it this way...
Validate inputs, then convert the "text" (Strings) to the data type.
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
' validate input
If Inpu.Text <> "" And rang.Text <> "" And offst.Text <> "" Then
'convert to data type
AI = CInt(Inpu.Text)
Range =
CDbl(rang.Text)
Offset =
CDbl(offst.Text)
result.Text = Resultaat
Else
MessageBox.Show("Invalid input", "Whatcha doing")
End If
End Sub
Hi, having some issues with scalings (SCP commands) with some Vegapuls 65 guided wave radar level transmitters. I've set the min/max in the...
174
I want to measure the tank level and get the sensor output to the PLC. Below are the details : Tank Height =0 - 3m, the sensor is stalled 0,2m...
629
367
I know nothing about simaticnet OPC server. I do know Kepware. I would only ever scale raw to engineering in the PLC, but it is possible to scale...
219
Hi all. I'm working on a rehab and I'm trying to figure stuff out. See screenshot at the bottom. Local:5:I.Data[6] in BTD instruction is a...
715
