scaling issue
agracing247
Jan 2021
Marietta
Hello all,
I'm having a issue with using the scaling instruction on rslogix studio 5000. I'm sure its something very simple I'm missing o_O but I can't think of the solution. I don't think its a data type issue and I've tried a regular input tag other than the analog input I'm trying to use. Below is a youtube video of the issue.
https://www.youtube.com/watch?v=-xU1e5hWR1Q
I'm using it as a source in my main program, but I'm not writting to it anywhere else. I've also tried creating new tags just to test it and it still doesn't work.
Your subroutine will only get executed if START is true.
Perhaps that is the reason your scaling is not working ....
agracing247 posted a link to a hosting site, and I know so many of you don't like clicking on links....
So I have attached the image he linked to ....
Hello all, First post here. Hitting a wall with finding info on this topic online, and none of my coworkers have a clue. I have a PanelView...
1,362
I'm having a strange issue where the operator can input a desired speed in 0-110%, and the scaling will correctly translate that in Hertz to the...
2,310
My 1771-OFE analog output card was previously configured to Voltage output OFE1 (voltage version), all four channels are 0-10Volts corresponding...
18
7,218
Hi, im using a wago 750-455 connected to s7-300 cpu I use fc105 but the scaling is not right, the value is 20% off. Almost like the fc thinks im...
4,362
Hello. I am having trouble getting my RedLion G315C (Crimson V3) to properly scale a value, and quite sure it's something I am doing wrong. I am...
2,552
