Scaling PT100 with schnider m211
Hi Group, I used the scaling block in RSlogix5K to display PT100 on HMI but the problem is, every time when I measure the resistance across the...
10,428
I have a scaling problem. I have a 2-wire analog 4-20mA input. There is a PT100 connected to it with a range from -30 tot +60 degrees. What I...
41
40,067
Hi, having some issues with scalings (SCP commands) with some Vegapuls 65 guided wave radar level transmitters. I've set the min/max in the...
162
I want to measure the tank level and get the sensor output to the PLC. Below are the details : Tank Height =0 - 3m, the sensor is stalled 0,2m...
625
365
