SCALING RANGE 4-20mA AB 17974 - OE4
TURG
Jul 2008
TEESSIDE
Hello,
Jusu a quick question.
I just need confirming what the scaling range/resolution is for an Allen bardley 17974 -OE4 out put card is.
I belive it is: 4-20mA = 0 - 32767.
Is this correct.
I know the scaling range/resolution for the Allen bradley input card 1794 - IE8 is : 4 - 20mA = 0 -30840. I am using one of these.
Cheers.
I have everything set up for vibration monitoring with the code in Controllogix 5000. The thing is that I am not able to read values SCADA in mm/s...
28
Hi, having some issues with scalings (SCP commands) with some Vegapuls 65 guided wave radar level transmitters. I've set the min/max in the...
195
I want to measure the tank level and get the sensor output to the PLC. Below are the details : Tank Height =0 - 3m, the sensor is stalled 0,2m...
675
407
I know nothing about simaticnet OPC server. I do know Kepware. I would only ever scale raw to engineering in the PLC, but it is possible to scale...
229
